Manual control of Danfoss Valve from a Room Thermostat
I'm looking for a room thermostat that can manually control the danfoss valve LC13 and works in HCL
So one should be able to override the heating panel from the room thermostat.
Anyone knows any please ?
4 answers to this question
check with Danfoss they do a zwave wall mounted controller but I'm not sure its available in the UK.
    I know the danfoss room sensor, but it is not integrated into the heating panel. It need a lua code to work, so no go on HCL
    So what IS included in the heating panel? As far as I know the Danfoss valves are not included in the heating panel, neither the Room sensor.
    I am looking for something to use in the heating panel...
    Danfoss Valves are included in the heating panel.  I have many of those working just fine.
    Danfoss Room sensor seems to have some issues.
