How to show running time in VD?
Guest samuelboerhoop
How do I show the running time of the HC2 in a VD label ?
6 answers to this question
There are lots of ways to do this. I created a button on my VD called "Remote On". This is the code i pasted in that button:
Where GLOBAL_VARIABLE is variable I created in the variables panel
I also update a label (Label12) to state the remote is "On"
I then have this code run in the main loop of the VD:
Label13 reports the time in seconds that the remote has been running.
You can create an Off button as well or you can run down a counter using the above. In this case the a timer is counting down from 100:
    Does your example shows the "Server status"  under HC2 > Configuration > Tab "General" > Server status ?
    I would like it to start automatically from the Server status, would that be possilbe ?
    There is probably a smarter way to do this, but if you want the timer to line up with the server status then create a new scene with %%autostart which means that it will automatically start when your HC2 boots up and then have that scene push the virtual device "Remote On" button I described above.
    See attached file.
    See attached file.
    Much better. Nice one!
    Perfect: that worked for me.
