Hey guys,
could you please help me, I have IP BELL videogate integrated in Fibaro, everything warks good. One thing what I want to do is to get notigication if someone push the button. Basically I need it for a time when I am not at home, so I know when someone is at the door.
Can you help me. I dont know which trigger to use for such scene. IP Bell allows those LUA commands:
I do not know ip bell, but
2n helios can send a call http GET if events occur in the video intercom (eg press button), your video intercom can do this ?.
another option
2n helios can call other device voip if the primary does not answer, then call an ATA voip to analog (eg HT-503), to make a call to a mobile phone, ip bell can make a call to another voip if not answer back?
    IP bell can call one device, if there is no answer it can call second one. Or it can call one device in the daytime and another device at the night time. that is not really issue.
    Only when the phone is not at local network, that is something i want to figure out.
    • 3 weeks later...
    Can you show us what type of videogate do you have?
    • 3 months later...
    Did anybody resolved the issue how to start a scene when somebody is pressing the door bell button ?
    I have ALPCHATECH Slim IPDP
    It runs with the IP BELL Fibaro plugin. It communicates well with FIbaro intercom, buttons are opening two gates.
    I need to start a fibaro scene when anybody is calling to the door, eg. to send a picture from the camera via email.
    I would appreciate any hint on this .
    I have the same problem with IP Bell and IP Bold. I didn't resolved this.
    what work is to parse last line of the call log, e.g. on IP Bold this is hxxp://ip-bold/logcall (check on IP Bell what is the log path, i think hxxp://ip-bell/cgi-bin/logcall.sh )
    When i see there line starting with "Calling" then someone just pushed the button, when "Incomming" then i started call from the Interkom app the IP Bold, and when "Terminate" then the call has been terminated (end of call). An VD checking the log each every 3 second should be fine for most users. One can create plugin as well, based on the IP Bell plugin, and add there the log monitoring, of course with result of monitoring as event of the plugin, that's all
    I have implemented the CallerID as described here:
    I have ASTERISK VOIP box running on Raspberry PI. The door bell can be registered directly to ASTERISK as SIP client, but I registered it to HC2 and defined trunk between HC2 and ASTERISK so the calls made from door bell to FIBARO VOIP are rerouted to the trunk connected to ASTERISK.
    On HC2 side I have Last Caller Name written to the global variable.
    If this variable is equal to "DOORBELL" then I can do action on my HC2 eg. send camera picture to email.
