I use this editor for my LUA programming, works with Windows, Linux and OSX
Hi Johnny,
I checked the editor out. I see it can handle a lot of programming languages, also json, but I don't see LUA in the list.......
Notepad++ as well does LUA
Second that. Notepad ++ works well.
I used notepad++, but I change for Sublime Text 2
ZeroBrane Studio Lua IDE used here
Thanks for pointing us to another fine tool to add to our toolkit. I'd like to point out that ZeroBrane comes with the Lua interpreter, so you can actually write and run some code. Of course, it doesn't support "fibaro:" so it's restricted to generic code, unless you write the "fibaro:" functions yourself.
/emoticons/default_icon_smile.gif" alt=":-)" /> I actually did that (like "fibaro:debug" does a "print") so I can run/simulate a scene to some extent. It's work in progress. When I see a Lua script on the forum, I try to simulate it and add code to my simulator until I can debug... One other editor, and certainly a "rising star", is "Atom".
Using Atom for a while now and i love it
I just installed ZeroBrane, can you explain how you wrote the fibaro:debug function?
I like the idea of being able to partially test code before running it live, but I can see it being a lot of work to create all (or at least the most commonly used) fibaro functions
I surely want to share how that works. I also would share the complete code (of my simulator), but if I posted it here, I would have to support it. Because I am still tuning/tinkering and sometimes trying out another approach, supporting it would be an impossible task. To give an example, you have to simulate how a "motion sensor" gets triggered. Or, how many Watt a Wall plug reports when it is switched on. Currently, I use a table with possible values, but that is too limited... The part that simulates http request is *very* limited at the moment. Anyway here's the "debug" code:
Here's an example thats a little more complex:
This function returns "autostart" if you don't do anything in particular. But for some users, I need another sourceTrigger. That is what the "simData" is about:
Next level up in complexity, is to allow a function call to return different values for every call. For example:
I use some sorcery-code (pun intended) to iterate over stuff, that's why Date/Time sits at the same level as device simulation. We're now talking about a total of roughly 100 lines of code to make this work.
The "simData.devices.Date.value" part is the table I've defined, but what is the "iter()" part? It's short for "iterator" and it's a function that is generated to fetch the next value in the array, then wrap. I cannot show the code for this function because it isn't there. There is code that generates the function. This is what they mean when they say "Lua has first class functions", meaning they are as flexible as variables.
This is an example that shows how difficult it is (nearly impossible) to get a perfect simulation. My os.date function only handles the argument types "%H:%M" and "*t". Anything else fails. But the beauty of programming is that nobody stops me from implementing a different argument, or rewrite this function. I probably have to, because the "*t" argument doesn't use the array, so that's a really bad and confusing implementation.
BTW you need to simulate, fibaro, net, Net, json and os, to be able to debug the most basic stuff. The os.date is needed to debug scripts that
Nevertheless, I hope this may inspire you to toy with ZeroBrane...
I hope jompa68 doesn't find this too much off-topic. It's about editing Lua in a broad sense, isn't it?
Have fun!
    Have fun!
    No, no not at all. Your help here on the forum and all the code you share is on a completely different level than the rest of us.
    Cheers m8
    OMG! That is on another level. You definitely deserve the rating of "I am the Matrix" when it comes to coding LUA!
    Thanks for sharing. I am not sure I have the time to do what you are doing, but good luck with it.
