LUA header - %%events?
All,
Does anyone know what happens if you don't have a header like this in v4.070+
%% autostart
%% properties
%% events
%% globals
I.e. do you have go an modify every script to include %% events?
You only need these headers if you want to do something with them..
so
%% autostart
%% properties
%% events
%% globals
is just as good as:
%% autostart
and if you ONLY want to trigger on global variable you use
%% globals
nameofvariablehere
and if you want to auto start and trigger on change of value and change of global variable
%% autostart
%% properties
100 value
%% globals
global variable
where 100 is the id of a device
