Roller Shutter v2 curtain positioning
Dear Automation Gurus,
I do have my Roller Shutter 2 working along with the motorized curtain. I did all the hardware setup and it works quite well however since the size of my window is smaller than the curtain itself I'd like to setup start and end position being different than physical beginning and end of the track itself.
Is there a way to limit the track motor movements so it moves from certain position?
thanks in advance!
Guest fat
There should be a way of setting limits for most motors. I don't have curtains but I do have roller blinds and there are hex key holes on the motor that are used for adjusting the limits
    Haven't seen any hex screws there but it could very much be those are inside the case.
    Any way to achieve the sane by means of any controller's parameters?
    i use parameter 22. this tells the module how long to run the motor for. this setting is used for both opening and closing of the curtains.
