Hey,
Fibaro Support said it is not possible but I know some guys here can do magic so:
Is it possible to show variables with HCL in mobile app?
The problem is that my client need to turn on/off holiday mode for heating in mobile app. We did this, it is working. But now if he turns it on or off, he has no idea unitll he check it in PC.
So I was thinking to do it as a label in VD but even the descrition says call:fibaro which we can not do in HCL.
Can anyone help me find a solution? It is not a problem to change the variable, we can give it to the scenes, we can do whatever but I need to have info about the status in mobile app.
Thanks for any suggestions
would also be keen to see if this is possible
thanks
I assume that your client puts the valves to a specific temperature in holiday mode?
As a workaround, you might write a scene monitoring the setting of the valves, concluding if it is holiday mode or not and sending a pushmessage of the status.
    Pushmessage is not an issue, the problem is that he do the same thing every week. He is home for few days and then he goes to work for few days. With push message you will eventually be alright first few times, then you will just take it as standard and not remembering anymore, if you actually got the push or not. We need something what he gets when he enter the app.
