got a question about debug
if got a script with
local lamp = {22,55,66}
for i = 1,#lamp do
lightItems = lamp
if...... etc
when i debug this i get three times the same debug
if i change local lamp = {22,55,66} to local lamp = {22,55}
i get two debugs
and when there is only 22 i get one debug
how can i change this to always one debug
thanks
I don't understand the question. If the "debug" is in the loop, then you get a line for each member of the array. If you don't want that, use an "accumulator string". That is: make an empty string before the loop. In the loop, add data to it. After the loop print (debug) the string. Can you please post some runnable code? Or use your actual code (10 lines max), but remove the non interesting parts?
    i think that is exactly it (you do understand me
    /emoticons/default_icon_biggrin.gif" alt=":-D" /> )
    the code partly
    local lampBuiten = {22,55,66}
    local sunrise       = fibaro:getValue(1, "sunriseHour")
    local sunset        = fibaro:getValue(1, "sunsetHour")
    local timeNow     = os.date("%H:%M")
    local timeUit        =  os.date("%H:%M", os.time()-60*60)
    --Buiten lampen
    for i = 1,#lampBuiten do
      buitenLampItems = lampBuiten;
        if (((sunset > timeNow and sunrise > timeUit)
                or (sunset < timeNow and sunrise < timeNow)))
            and fibaro:getValue(buitenLampItems, "value") == "0"
          then fibaro:call(buitenLampItems, "turnOn")
          fibaro:debug("Buitenlicht gaat aan.")
        if (sunrise < timeUit and sunset > timeNow and sunset > timeUit)
            and fibaro:getValue(buitenLampItems, "value") == "1"
          then fibaro:call(buitenLampItems, "turnOff")
          fibaro:debug("Buitenlicht gaat uit.")
    --Buiten lampen
    if (((sunset > timeNow and sunrise > timeUit) or (sunset < timeNow and sunrise < timeNow)))
    then
    if fibaro:getValue(buitenLampItems, "value") == "0" then
    elseif (sunrise < timeUit and sunset > timeNow and sunset > timeUit)
    then
    if fibaro:getValue(buitenLampItems, "value") == "1" then
    /emoticons/default_icon_idea.gif" alt=":idea:" />  TOP
    zie het nu. zat hem zoals peter al zei "Het zit in de loop"
    Stom van me
