Help with sceneactivation from ZME_WALLC-S
Hi.
I'm having trouble getting scenes to work with the ZME_WALLC-S controller. I've red tons of articles (example:
and spent many hours trying to figure this out. Any help is greatly appreciated. I'm using HC2 with 4.081 Beta firmware. Please see screenshots of configuration of Keyfob device.
I've created a LUA scene for debug, but nothing happens when I'm pushing the buttons.
This is the code I'm using:
I've noticed that the firmware of the zwave.me controller is 1.1. And other articles are reffering to newer firmware of that device. I've also noticed that some are not using template and adding parameters 16 and 24 to the list (which I've also tried).
Right now I'm a bit in the dark, some help would be appreciated
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />!
6 answers to this question
hi, i use:
wake up 7200
par 1 and 2 set to zero
11-12-13-14 set to 4
for lua i use this:
    Hi.
    Thx for reply. Still no good. I did reset the controller to do everything with a fresh start.
    So it seems that I'm not able to even activate the scene. When I look at this device, nothing is associated (see screenshot). Must it be associated with the controller in any groups with a Single or Multichannel association?
    It must be associated with the controller... in my case all 4 groups are associated with HC2 "S" single channel.
    I have the same problem, scene activation stoped working after i installed 4.081. It worked just fine on previous firmwares.
    Thx guys, seems we have to wait for a new release of the firmware.
    just tried 4.082 beta, didn´t work! bah
    Only battery device i have that work with sceneActivation is Fibaro Swipe.
    UPDATE:
    On 4.082 i excluded the walls-c.
    Then i reset wallsc. In management mode i press button 3 then hold button 4 in for at least 4 sec.
    Add switch and everything worked for me!
    UPDATE 2:
    Even better Central Scene activation works!! Paramenter 11-14 to 8
    Even ZRC-90 Scene Master is working without template.
