Do you know easy way to use "ok Google" on Android?
Was just about to post it here
By the way, in your setttings:
["Comm1"] = {"kast licht aan", "licht kast aan", "kast aan"},
 ["Comm2"] = {"kast licht uit", "licht kast uit", "kast uit"},
It is unnecessary to add a text variation that includes all the keywords already present in other variation, since the latest will trigger also the former.
i.e.:
"kast aan" is more generic than "kast licht aan" and "licht kast aan".
You can say "whatever kast otherthings aan and many more words", and Comm1 will be triggered.
In fact if you have a look to my settings:
["Comm4"] = {"radio off", "sonos off", "music off", "mute radio"},
My kid's favourite command is "Please switch that boring music off" ...
And it works...
Yes I changed that already.
Once again thank you for the code.
  • 3 weeks later...
Guest Roman
    • 4 months later...
    Thanks Brick for the code. BTW I found a potential bug which took me some time to troubleshoot.
        ["Comm9"] = {"reception lights on"},
        ["Comm10"] = {"reception lights off"},
    Essentially given the above commands and with a spoken command of "reception lights off", both comm9 and comm10 will be triggered because "on" is also in "receptiON".
    On 5/17/2016 at 5:42 PM, Brick said:
    match = match and (string.find (speech, word) ~= nil)
    Due to the above string.find command. My workaround is:
    match = match and (string.find (speech, '%f[%a]' .. word) ~= nil)
    Hope that helps someone.
    Edited by vblues
    • 3 months later...
    Guys, this is fantastic thanks. I have a small problem though: whatever phrase I say, it's also looked up by Google on the web while it's being passed to Tasker. How can I disable this and make sure that if I say "open gate" I don't search the web for "open gate" and if I say "insert alarm" it doesn't try to set the alarm clock?
    Thanks a lot!!
    R
