Main Temperature and Humidity sensor in Rooms from a VD
Is it possible a asign a non z-wave temperature or humidity sensor as the main temperature or humidity sensor in a room.
I have several wired and wireless sensors in and around my house, that are now available in the HC2 as several Virtual devices.
It would be nice if the temperature and humidity readings could be asigned to the rooms by for example setting the type to com.fibaro.temperatureSensor
T= Temperature
H = Humidity
R = Radio signal (Zigbee)
When they relese plugins again you can do this with krikoffs exelent plugun.
    So it's just a matter of patience
    as always it is
