youless virtual device won't update after a while
Hi all,
I found a virtual device to read out my youless power meter. One problem, the HC2 stops updating it after a while. when rebooting the hc2 it works.
Below is the code, is this correct? maybe to many open sessions after a while in the hc2?
If i use the iOS app of the youless or the webpage it keeps updating.
%% properties
%% globals
local data
fibaro:debug("start")
if (nano == nil) then
  nano = Net.FHttp("192.168.11.250",80)
response, status, errorcode = nano:GET("/a?f=j")
fibaro:debug(response)
jsonTable = json.decode(response)
cnt = jsonTable.cnt
pwr = jsonTable.pwr
lvl = jsonTable.lvl
fibaro:log(pwr)
fibaro:debug(cnt)
fibaro:debug(pwr)
fibaro:debug(lvl)
-- deviceid 32 is my youless device ID
fibaro:call(32, "setProperty", "ui.lbl181.value", cnt.." kWh")
fibaro:call(32, "setProperty", "ui.lbl182.value", pwr.." Watt")
fibaro:call(32, "setProperty", "ui.lbl183.value", lvl.."%")
-- fibaro:call(32, "setProperty", "ui.lbl184.value", dev.." ")
fibaro:sleep(10*500)
anyone got's an idea?
7 answers to this question
Hi Barend
Try this else below nano = Net.FHttp("192.168.11.250",80) and end at the end öf the code.
second suggestion to try
I have a simular code where I used POST instead of GET in  response, status, errorcode = nano:GET("/a?f=j")
Why do you want this to run every 5 seconds? (fibaro:sleep(10*500))
PS. the else is not correct, it will never run the first time like this.
for sure it will work. Maybe not the first cycle, but from there it stays up and running.
See the code of a VD that I have running now for two months
    I would like to run it every 5 sec for a accurate power readout. Like the app and the website does
    Mr. Jack it works perfect! Thanks a lot!
    Mr Jack why do you prefer post? What is the difference?
    I used POST because GET didn't work. So that's why I prefered POST
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    Glad that it works now.
