Akash 0
I have the following:-
1. Fibaro HC2
2. Fibaro relay (connected to boiler)-
3. Danfloss Valve
4. Fibaro Light/Motion Sensor.
I want zone by zone heating in the house. At the moment I am trying to get the Lounge working and possibly once that’s working move on with the rest of the house.
I have created a heating panel (for the lounge) I have set the main thermostat in the lounge to be (Danfloss), main temperature sensor (fibaro temp sensor).
Now I have couple of questions:-
1. What is the scene I have to write so that the boiler relay is turned on? For example the room, at the moment is at 22deg, the panel is set at 25 deg. So how do I make the boiler relay “On”. Also, for example, if the room is 18 deg and the panel is 15deg and I change the temperature on the danfloss (via the HC2) to 25 deg. How will the above scene cope? Hope I have been clear here.
2. Now if I do multiple rooms i.e. living/dining/bedroom. I see there is no “Or” gate to enable the boiler relay. So if one room calls for heat and the relay is on, what happens when the another room says I have reached the temperature and turns off the boiler? Can you let me know of the appropriate scene for this as well please?
From my research on the forum, the answer to the second part of the question, is maybe have multiple relays, which i think will make this too expensive.
Please if possible can any of the solutions be wrt to non LUA solutions. Screen shots or picture of scenes as well if possible please. Sorry i have no clue about LUA.
Thanks,
Akash
12 answers to this question
