HI I have been using a virtual device to trigger motion detection on my foscam IP camera and all works great. But now I am trying the same thing with a D-Link DCS 932.
I have the turn motion url from a browser and all works great
- sending this from a browser works every time.
When I add this to my virtual device (the same process as my Foscam IP Camera)
GET
HTTP/1.10x0D0x0A0x0D0x0A
Pressing the arm button and nothing happens, If I substitute it with the Foscam URL etc the Foscam arms from this virtual device, so I know the device is working.
Not sure why the same setup works well with the Foscam. And I can test the above url in a browser for the DLink and that works fine so the command is correct.
Any thoughts help would be appreciated
thanks
7 answers to this question
    anyone struck this or have any thoughts
    I tried to do the same with D-Link DCS 942L.
    I tried with several settings and several ways of authentication. I never could manage it to work (while I did with Foscam and Vivotek camera's).
    I think the problem is within the authentication method.
    Yeah would have to agree just cant seem to find a solution
    I'm not an expert at all but i see dlink cam is port 81. Hcl is using port 80 for http maybe thats why its not working. Can you change dlink port?
    @reintjan All my camera's are using other ports so that might not be the reason.
    Edited by wpeeters
    fast post
    Ok, just a thought :-)
    HI just an update if anyone has struck it but since 4.131 mrs foscams can no longer be armed etc with this virtual . Both were working now neither works. Nothing else was changed
