Was anyone able to successfully associate fgs222 with merten 5052xx wall switch? I can easily add fgs211, Dimmer2, some other devices to Merten Groups 1,3 but not my fgs222 - it just does not get added.
I dont think fgs-222 was included in secured mode but is there a way to find it out (it is embedded in ceiling lamp now)?
  • 2 months later...
I have a similar problem associating a Merten  5052x (Schneider WDE002903) with a fgrgbwm-441 on channel 3
And as you did I also have been able to associate the Fibaro Dimmer 2 module on cannel 1.
Maybe the reason we both fail is because we try to do multichannel associations? Would this be a problem with
fibaro HC or Merten?
I am using HC2 v4.090 and have been trying to do both normal association and multichannel but it never takes
after I save the association in HC2 and wake up the device the association values are gone from the HC2.
I have set parameter 0, 1, 2 and 3 to the value zero, like it's described here:
I don't know why the templates in HC2 are wrong.
I thought that a fallback would be to associate the marten switch with the controller it self (device id 1) but I don't know how to write a scene
to catch the "BasicOn" event (or whatever the switch will send). I guess this is not even possible, other controllers have this function but I have
never seen any one do this on a fibaro HC2.
