Anyone knows how to integrate a door lock with fibaro system ?
I am looking for a door lock that can communicate with fibaro.
Is it possible ?
You need the z-wave-Version.
    Thank You so much.
    But is there any other doorlock that can be integrated with fibaro?
    Yale Lock maybe ?
    Yes there is also a yale z-wave doorlock.
    • 1 month later...
     Not sure which part of the globe you are on, but there are a few locks for z-wave, the Yale ( or Lockwood in my part of the world ) is a deadlock or also comes as a handled lock, has nice glass pin pad, and can be remotely opened and closed. These are the ones I have, but to be honest i haven't tried updating mine for ages, which is a good sign as it means it becomes I will try and do that this weekend, to see if we have any pin generating and recovery options yet.
    ( it would be nice to make a pin and give it to someone as a one shot use etc )
    As a lock it has been reliable and it has been pretty well supported throughout the versions and Beta's since about 3.080, but not sure on the additional functionality other than open and close.
    1 little heads up is add it to the network in encrypted mode and have the lock very close to HC2 prior to installation .. also give it a long time to connect and settle itself into the network, mine are notoriously painful to add ( hence I haven't tried remove/add for a while )
    You could also check out the
    range of locks I believe they are OK with HC2 also.
    Cheers,
    al.
    Alandee, can you please let us know how you updating the Yale/Lockwood lock? Thanks.
    Thank You so much.
    Yale Lock maybe ?
    Mr. Ramy you can check out Yale lock model - YDM3168
    Note : Need to install separate module to make it z wave.
    You can check out Yale YDD424 and YDM4109 too.
    Similarly, they required separate Z-Wave module to be plug in.
    • 2 years later...
    hi
    ho to add yale YDM4109 in HC2
      hi
    how to add YDM4109 in HC2
