jcta 0
When I use Fibaro application on my Ipone at home, I see correctly the video of my cams (3x Axis MW207), but ....
Accessing the same Fibaro application via GSM (that is not through local WIFI), I still control any device, EXCEPT that I have no more access to the video from cams (try to get video flux and then display an icon with ''no video'' label ).
Is there some restrictions due to the bandwidth, (3G used, not yet 4G
/emoticons/default_icon_sad.gif" alt=":-(" />) , or I missed someting in the configuration ?FYI : no problem to get the camera video using other application (on the same iphone , with GSM 3G) ,. I mean the video flux can pass easily the router(s).
Any solution ?
