Hello Fibaro dev team.
I come back with this subject, because now V4 is stable (Only 503 problem for some people, but you will find fast now).
So the question : Could we see back the personal plugin, almost in beta version ?? It would be great, because we are waiting since 18 month for them... And when we are looking other domotic boxes, all have this option now. If you could give some informations about release of them again ??
    No more infos ?
    Please god not yet! Last thing this device needs is more features at the minute. Fix the bugs first!
    I would love personal plugins but not yet!
    Why ?? Because you have problem ? We are a lot people which have no problem with our HC2, and still waiting since 18 months...
    As explained, this is to put in a beta version, for testers only. If you not want that, simply keep stable version.
    But if you come to french forum, you will see that a lot of people are leaving the HC2 for other solution, because waiting too much time for this personal plugins...
    Bye then
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I'm not French and I have more patience!
    Even the releases recently had issues. Let me find you a rock to hide under. Personal plugins are a security implication so I'm happy to wait.
    To be honest I'm running 4.082 and I'm pretty sure I could install personal plugins now if I tried!
    Yes, it is working installing them. Easy. But on each update, you loose all...
    So your "bye", keep it for. You have a problem with new thing, keep on stable version, don't try beta, end of discussion.
    Because you have problem in 4.082, all must wait ? We are a lot of personns for who 4.082 is stable, so now go further.
    seriously if you cannot see obvious bugs in 4.082 you want stringing up pal!
    For me, only a 503 at the beginning because a problem in a VD of my fault, 100% stable. So what could I had else ?  My development in prod are better than yours
    Well done... i will sleep much better knowing i can fill my tank tomorrow! thank you...
    learning so much reading you...
    French guy from earth...
    In positiv or negativ
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> ?
    The message wasn't in regards to you frenchy Niochi
    Back on topic... there is an issue with current firmware and sensitivity to mainloop still. So when you see another potential fix in upcoming firmware release feel free to pull your head out of your pompous rear end and throw some apologies around
    Plugins are a security issue as previously stated! Not a top priority right now... and if your box is not crashing then your obviously not using it to its full potential!
