m-joy 3
Hello everyone,
i have this scene:
What it basically does is getting triggered when the ID of the fibrao power plug 248 changes.
Then it checks for a certain power value. If this value goes below a defined power value, the scene goes in a loop of 10min where it checks once a minute if the power is really below this value and then shuts down the power plug.
Now first of all the scene gets triggered kind of often, which may be unlovely but may be okay.
Second thing is that i use a delay to get my 10min timer.
I know there is a way to trigger a separate function with a delay which may be a solution (damn i can not remember the paramteter for that function) .
But i am not sure of how to exactly do this:
1. Trigger scene on power change
2. Check if power is below that value
2.1 if not do nothing
2.2. if so Start a scene delayed for one minute and check again if the value if below my definition
But what if the value is below that definition now? Can i trigger the delayed function again inside this function with the delayed start function ?
Would that be better? Could that work?
Greets
