kaznad 0
I need some help wiring the Dimmer 2 module. Attached, current.jpg is how my light switch is wired up.
If I understand the wiring correct, I plan to wire the dimmer up like this, attached planned.jpg. There is a wire bridging switch 1 and switch 2, I should leave it as it is right?
Is my planned wiring correct? I only plan to control switch 2.
Thank you.
