I am struggling to understand how the heating panel works together / or not with the AC panel.
The setup is like this:
In the same room there are: 2 Danfoss radiator valves LC13, 1 Room Thermostat Danfoss RS, AC controlled by a Remotec ZXT-120.
During the winter I have "moved" the 4 Remotec icons to a dummy room as AC was starting on heating whenever the heating panel demanded to turn up the heat and I wanted to heat the room only using the radiators.
Now it is getting warm outside and I will soon need to cool down the room. So what I did is I moved back the Remotec controls to the room, set the main temperature sensor the Danfoss RS, set up the AC panel and I hoped I will start to cool down the room by turning the AC on cooling. No dice... Radiator thermostats just followed the heating schedule and AC turned on heating.
So I disabled the heating panel and left only the cooling panel. Still no dice, AC does not turn on cooling.
So I guess my question is: how are these panels supposed to be set if I got all of the above devices in the same room but during winter I want to heat only with the radiators and during summer to cool with the AC?
Thank you
PS: or is there a bug and the Remotecs are integrated in the heating panel but not in the cooling panel ?!
Would be great if someone from Fibaro could shed some light on this.
    You can do it in the same scene. Just be aware that for different brands of AC the commands might be different. Easy to see just by looking at the device from the left panel.
    To run it continuously just delete the time statements.
    how the commands be different ? i mean every brand in that device has trigger On and Off , heat and cool, fan speed etc.
    I have no idea hence the "might be".  Commands should be the same.
    Ok. Thankyou it helps me a lot.
    One more question. From where did you learn lua coding for fibaro? i have searched on the internet but didnt find the basics. There is no e-learning course provided.
    Here, maybe you will find these links useful:
    @T.Konopka welcome back to the thread
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />  Please let us know the status of the integration of ZXT-120 into AC panel as well as the Danfoss RS into the heating panel.  This thread is not yet solved or explained.
    Thank you.
    Thankyou T.konopka.
    I will look into it.
    Thankyou T.konopka.
    I am having trouble with fibaro relay. it does not respond. Even on off switch is not responding. Lights remain on . It had  worked fine for few days only. What should i do . Please give me any possible solution.
    The firmware version is 4.054 on HCL ( home centre lite) . Could it be a issue of firmware?
    Thankyou.
    Please, create a post in the proper category with this question or contact our support.
    After doing so, please delete or edit your above post.
