I already succeeded to integrate the ITach WF2IR module with Fibaro system.
But, I am now looking forward to doing the same thing with the ITach WF2SL (Wifi to Serial Communication)
I have several questions here:
1) Is it possible to integrate it with Fibaro ?
2) With the WF2IR module I controlled any IR device like AC or TV. I was wondering what can i control with the WF2SL module ?
     If anyone can state some applications that can be done with this module ?
3) With the WF2IR module the programming part was sending the IR codes of the devices to be controlled through the Fibaro virtual     device. What about the Wifi to Serial Communication ? How is it going to be programmed to be able to control the devices through Fibaro system.
I am talking about this device.
Thank You.
you can controle your reciever or other things with RS232
the sending part is the same
    Can you please illustrate a specific application ?
    An application that can be done with WF2SL which can't be done with WF2IR ?
    Control a unit that has a serial connection and no IR connection
    If you will make some code in LUA, you can control Paradox security system.
    Some TVs is better control with RS-232 than IR.
    Now GC has a RS-485, but it is for iTach Flex not WF2SL i think, so you can control Recuperation units with that.
    I think Onkyo respond faster if you have connected it with RS-232. In our showroom we have our DRX-3 connected with IP and RS-232, to show our customers we know both ways how to control it.
    With RS-232 you will have feedback of the command you send, so far more reliable compare to IR (in my opinion).
    • 10 months later...
    How to deal with feedback?
    This is an example to control a TV with RS-232 (power on):
    You know if you have an error and if the feedback is correct, so you really know the state of the device and of the command did succeed.
