Best heating control system, that will interact with HC2.
Hi, I'm having a surface water open loop heat pump fitted and the company that is doing the work want to fit a HeatMiser control system with normal radiator thermostats.
There will be 3 zones, upstairs, downstairs and a separate zone for towel rails.
My first question is can the HeatMiser System be incorporated with the fibaro HC2? Or what is the best alternative, the company fitting it isn't keen on the Honewell Evo Home(which I like) or Nest.
The other option is a Horstmann thermostat and danfoss trv's.
What are everyone's thoughts?
Not keen on evohome? Why not? By far the best system I have owned and I ditched my Nest then Danfoss for the Honeywell... by far the best and most reliable
    Not sure why, he couldn't really give me a reason. I've read a lot or reviews and had a play with the app in demo mode and was quite impressed with the Honeywell system.
    Has anybody used the Horstmann and danfoss combination with the fibaro heating pannel?
    Honywell is the best for me, but the great script so Remko!
    i have had danfoss and zwave wall stat experience... battery zappers! and danfoss have never been 100% still get the odd loss of communication with zwave engine direct communication or not!
    heating is important don't let zwave control it
    /emoticons/default_icon_wink.gif" alt=";-)" /> you will regret it i think! keep them separate and maybe wait for custom plugins to work again and then you can tie the heating system in with virtual sensors maybe? if krikoff adds that function
