Hello guys,
My plan is to activate a scene when it is the prayer time.
The issue is that this time is changing during the year. So everyday it is something.
I found an API which responses with a table with the prayer time
I dont know how to integrate it to HC2
Will you help me?
12 answers to this question
Create VD and copy code below to main loop
Create global predefined variable  naming  pTable.
Please change sceneID to your real scene ID you want to execute.
That's the basic idea to use API and Json table, but you can change it as you wish.
Good work , thanks for help but there any possible to get something like that to HCL
Thanks in advance
Edited by Abdalrhman
    THANKS A LOT!!!
    Will test and ill let you know if any inquires !!!
    Appreciate your help
    There is no possibility to write LUA on HCL and there is no way to do it with block scenes.
    Sorry
    Sorry
    I finally get HC2 and I am trying to test this script but I got this error in attached picture .
    Thanks in advance
    The problem is with global variable definition... but to solve it and make it simple please use code above. No global variable required
    This code will get prayer times every two minutes and will run your scene accordingly to prayer time.
    good idea and good experiment on
    Can you explain to me how to make it work, i have added a new VD and pasted the code in the main loop and changed the scene id to AZAN to work what else need to be done to. as nothing works yet. also regarding the VD do i need to put any ip to port? or what scene should be their?
    i have created my own Prayer Time VD for HC2 and QA for HC3
    it uses your own set times and all calculations are done based on offset times which you decide and a fixed time for Zuhr.
    i will create a video shortly and upload to my channel.
    you would also need sonos speakers to be able to listen to the Azan.
    Looks like this site not free anymore and you need to use API Key...
    see
    Edited by cag014
    6 hours ago, cag014 said:
    thanks will try
    Hi
    i found that these sites only catered for the capital city of the country and so therefore i a have been using my own verison of prayertime which is auto adjusting on a daily basis basedon sunrise and sunset times. Zuhr prayer is an offset of a fixed time. With this a VD or QA is used to do minor tweaks if needed.
    See videos and all associated files which are downloadable from my channel here:
    HC2
    HC3
