I have 2 RGB controllers setup in the same area and need them to work in tandem. Basically when I pick a colour on one controller, I want it replicated on the other automatically. Is that possible? If yes, Does any one have instructions?
I have a home center lite.
Thanks in advance.
4 answers to this question
I want to know as well ...
Look here:
    Thanks, but these instructions are for Lua based programming which I understand do not apply for Home Center Lite? Any similar instructions for HCL?
    Hi
    If its in the same area, you can use the rgb amplifier and finish the installation with just a Fibaro RGBW Controller itself.
