I tried geolocation service a few times but never got it to work. I would say it triggered in 50% of my cases. Anyone really use this in practice?
Meaning...
- Reliable GPS feature to be able to trigger arrival / departure from home.
- No intensive battery drain.
If yes, how?
I created a LUA script to log the trigger of arrival and departure and the saw that it very regularly failed to trigger despite 5 min polling. At the same time I used "locative" app iOS and that was 100% accurate.
4 answers to this question
Guest tiimbo
Hey, i run Domoticz on a synology nas which handles geolocation, domoticz integrates nicely with fibaro and has its own app which uses google locations, so battery drain is minimal, has worked flawlessly for about 6 months. Had to pay for the app on my wifes iphone, but android is free. So simple too, flicks a switch in domoticz to on or off which updates a global variable in fibaro.
if you want more info let me know.
    Thanks! So fibaro app is still not working?
    I uses a Domoticz server too as a spare. What service do you have installed and what app do you use for the GPS feature?
    Hi, I'd like to know more. I initially had domoticz on my synology nas, then moved over to fibaro and woould like to get some kind of working geofencing. I still have domoticz on the nas.
    How do I integrate domoticz with fibaro?
    I would appreciate step by step guide on integration domoticz with fibaro
    thank you in advance ...
