My Sensor Temperature
HI,
I have a few MySensors temperature devices that I got into my Fibaro HC2 via Domoticz and FibaroLink.
I have now the Temperature of the sensors as a virtual device. (Steps on how to do it is
What I am trying to find out if there is a way that I can set the Virtual Device as my main temperature for the room?
Because it's not a device I cant seem to select my virtual device.
Any help will be much appreciated.
Chris
Unfortunately you can not
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />  The only thing you can do is LUA code.
