Hi All
I can't explain why my turnon command is never or sometimes run. The fibaro:debug is always displayed meaning the scene is running but my wallplug (ID 636) is sometime run, sometimes not.
I can control my wallplug from mobile app meaning there is no range issue
I think it just missed the trigger time.. z-wave traffic could cause this. I would set time interval of 3 minutes for example, check if the device if on already , if not then turn it on.
Or make the loop shorter then 60 seconds.
You are checking now on 60 seconds loop to turn on in the same 60 seconds - minute 30.  It can miss at times.
    Thanks for your reply and suggestions..
    I don't think it could be a miss of the trigger time because I always have the message from the fibaro:debug so the scene is always triggered..
    Maybe z-wave traffic whereas at this time, I don't have many sensors in action
    I think I will add a loop until I succeed to turn on the wall plug..
    I thought z-wave managed acknowledge receipt of a command, meaning if I send a command and the command is not send because of traffic for example, the command was sent again. I thought it was not on the user side to do that but it was a feature of z-wave !!!
    I wonder why it doesn't work suddenly whereas it was working since more than 1 year... the HC is at the same place, same for wall plug...
    It is this instability I don't understand !!!
    Having the debug doesnt mean the command it was actually sent and received. Try lowering the loop to 30 sec and see what happens
    Because I have a scene to turnOn the wall plug and the same to turn it off, I lowered the first one to 30s and for the other one, I modified the loop condition to restart the turnOff until it works.
    I will inform you tomorrow
    As if by chance, it works this night in the 2 cases without any need to restart the call...
    I added in the 2 cases a fibaro:sleep(5000) after the call, maybe it can have an impact !!!
    Case 1: variable to check if I need to restart or not
    case 2: lower loop (it works 2 times)
