First of all, make sure you're using the API correctly by issuing some basis commands like turnOff/turnOn.
http://<fibaro_ip>/api/callAction?deviceID=<deviceID>&name=turnOn
e.g.
/api/callAction?deviceID=5&name=turnOn
You should see this response:
Remember that any device or scene you're trying to manipulate needs to be accessible by the user. If a device is to be turned on by a global variable changing then the device as well as the scene must be accessible. In your case the VD as well as anything else in the chain of events needs to be accessible.
Thanks, for your help,
I will try it at the weekend
to make it easier I changes the device to a lamp and the user has the rights for it.
my IFTTT looks like this.
where should I see the response?
for the API, do I need to set anything in the HC?
This is my first time to use this functions.
Cheers
:-) Thanks for help,
it's working :-)
Can I also directly set a variable value?
What is the command for it.
Where can I find more commands for this API?
thanks a gain it's great feature.
Cheers
Have a look at
 for documentation on the API.
Setting a variable is done by a PUT request with a json payload:
Thanks, I will try it.
