Is it possible to switch the relais (independently of IN1 and IN2) ?
I could not find any command.
(I bought it to switch two LEDs. Impossible?)
Thanks for answering
as the name is sensor and not switch, it is read only. You can connect an external switch to it (e.g. Doorbell button). then the output will react to the input.  there is no possibility to change the state of it by fibaro commands.
I think you need this one :
I had the same question when first using the binary sensor. A compact device like this would be useful for controlling ELV (12V) loads with a dry contact rather than mixing voltages with the FGS-222.
Being able to separate the input from output would be extremely useful too!
