Following a battery change on my Fibaro FGSS001 smoke detectors I was unable to get the battery indicators in HC2/HCL to update.
I turns out that there is a small mistake in the instructions explaining the procedure for battery replacement.
The required procedure is to remove the exhausted battery, press and hold the B-button for 3 seconds (or more), insert the new battery, and then to press the B-button (quickly) three times.
JASEDK
JASEDK
So now, you can see the battery indicator for your FGSS?
