Hello.
I installed a UPS in my house wich is monitored and controlled by a Raspberry Pi.
Is there a posibillity to shutdown the HC2 with an API command via HTTP from a Rasperry PI?
There will be a power down for about 3 hours next week in my small town, my UPS can keep up the power for about 35 minutes.
So I'll try to shutdown the Rasperries and the HC2 if the load of the UPS is smaller the 5%.
I would be happy if there is some solution out there
[EDIT]
I forgot to tell that the Firmware fo my HC2 is 4.056.
[/EDIT]
Hi Armin, you can create a scene with
  • -- Shutdown system
  •     HomeCenter.SystemService.shutdown();
and call it when needed
    Hi grimy112,
    my HC2 is still running under Firmware 4.056 and "HomeCenter.SystemService.shutdown();" is implemented at FW 4.08x and above ...
