Multilevel slider minimum and maximum
seiq
The slider for a multilevel output (ie: dimmer) should scale based on the minimum and maximum levels setup in the parameters for the device.
Example:
Minimum device output level set to 20%
Maximum device output level set to 70%
Slider 0% = 20% output
Slider 50% = 45% output
Slider 100% = 70% output
As of v4.082 the slider is set to the actual output %. This makes devices with a narrow min/max range hard to control.
