WhiskeyAlpha 0
Hi All,
Sorry if this is blindingly obvious (I've looked through the instructions and searched the forums here before posting) but I've recently just added a Danfoss LC13 to my Home Center 2 and I'm a little confused about something.
I understand that to preserve battery life, Z Wave devices which use batteries generally have a "wakeup" time, which means they only switch on to communicate with the controller at set intervals. For the Danfoss TRV, this appears to default to 900s (15mins).
What I don't quite understand is the in the Home Center interface, I'm offered two variables to change - the set point (desired temperature) and another parameter which stipulates a time value between 0 and 2 hours.
What does the time value represent? Time until the desired setting will be applied? How long the new setting will be set for? Neither?
Would appreciate any advice.
Many Thanks
