an other youless VD problem
using the VD from youless (power readout) after a while it stops and de debug view shows this:
[DEBUG] 00:31:33: start
[DEBUG] 00:31:33: {"cnt":"61945,508","pwr":206,"lvl":0,"dev":"","det":"","con":"OK","sts":"(37)","raw":0}
[DEBUG] 00:31:33: 61945,508
[DEBUG] 00:31:33: 206
[DEBUG] 00:31:33: 0
[DEBUG] 00:31:41: start
[DEBUG] 00:31:41: {"cnt":"61945,509","pwr":205,"lvl":0,"dev":"","det":"","con":"OK","sts":"(29)","raw":0}
[DEBUG] 00:31:41: 61945,509
[DEBUG] 00:31:41: 205
[DEBUG] 00:31:41: 0
[DEBUG] 00:31:49: start
[DEBUG] 00:32:10:
[ERROR] 00:32:10: line 20: Expected value but found T_END at character 1
This is the code and I tried to if then else out the null value, but apparently its not a null value to handle. Anyone a idea? Code is below and many thanks!
%% properties
%% globals
local data
fibaro:debug("start")
if (nano == nil) then
 nano = Net.FHttp("myserver",80)
else
response, status, errorcode = nano:GET("/a?f=j")
fibaro:debug(response)
if response == nil then debug('response is leeg') else
jsonTable = json.decode(response)
cnt = jsonTable.cnt
pwr = jsonTable.pwr
lvl = jsonTable.lvl
fibaro:log(pwr)
fibaro:debug(cnt)
fibaro:debug(pwr)
fibaro:debug(lvl)
-- deviceid 32 is my youless device ID
fibaro:call(32, "setProperty", "ui.lbl181.value", cnt.." kWh")
fibaro:call(32, "setProperty", "ui.lbl182.value", pwr.." Watt")
fibaro:call(32, "setProperty", "ui.lbl183.value", lvl.."%")
-- fibaro:call(32, "setProperty", "ui.lbl184.value", dev.." ")
fibaro:sleep(5000)
5 answers to this question
The response is empty, try:
if response == nil or response == "" then debug('response is leeg') else
And add, just to be sure:
fibaro:debug(status)
fibaro:debug(errorcode)
    great! I just added the extra code and let's wait for the error
    put the wait on 500 (half second) and after a few minutes the devices crashed and a 503 went on.
    I fixed it with some code a few months ago and here to share:
    %% properties
    %% globals
    local data
    -- change IP address to your address!
     nano = Net.FHttp("192.168.11.250",80)
    else
    -- if response==" " then response = '{"cnt":"61945,001","pwr":516,"lvl":1,"dev":"","det":"","con":"OK","sts":"(47)","raw":0} '
       then
       fibaro:debug("response is empty, values are set to zero")
        cnt="0"
        pwr="0"
        lvl="0"
    --    response="{"cnt":"61950,318","pwr":599,"lvl":0,"dev":"","det":"","con":"*","sts":"","raw":0} "
    --    fibaro:debug(status)
    --    fibaro:debug(errorcode)
        else
    cnt = jsonTable.cnt
    pwr = jsonTable.pwr
    lvl = jsonTable.lvl
    fibaro:log(pwr)
    fibaro:debug(cnt)
    fibaro:debug(pwr)
    fibaro:debug(lvl)
        fibaro:sleep(5000)
    Also put the virtual devices as an attachment with this post. !
    have fun with it!
    The only thing that's missing here is how to add this with a password protected youless. Any idea?
