miersd 0
I have installed an FGR-222 on a Smartthings Hub, using Toggle switches to control Warema Blinds. All configured and working OK.
I have read that earlier versions of this Module had motor protection -- i.e. the module did not allow a voltage to both up (Q1) and down (Q2) at the same time. Is this the case on the FGR-222?
Specifically, if the Roller Shutter is moving as a result of a zwave command, and somebody presses a toggle switch to try and stop the movement, is the motor protected? --- or do I get a bang and lots of smoke?!
Can anybody point me to documentation regarding this? (It would save me time, as otherwise I have to set up a rig to test all the different scenarios!)
Many thanks,
