HTTPS command using VD
Hello
I know how to make http post like that:
But how to make it if:
192.168.0.101 are https ?
5 answers to this question
Not possible with VD, for https you need a scene.
    Can you help me with example how to make in scene ?
    An example made by boerremk:
    EDIT: Looking at your initial request you can use the code made by boerremk to send your https request. Looks like you want to control a multichannel relay device, right?
    Maybe you can store channel and switch command into a global variable using a VD.
    When the global variable is changed the scene automatically picks it up and sends the https request.
    Just change the boerremk code to you needs.
    Just my 2 cents...
    Edited by Lambik
    FYI, additional info can be obtained from the Fibaro developer site at
    Section: Plugins control --> HTTPClient Class Reference
    You have to register to get access.
    Thanks Lambik
    It's work fine for my solution.
