I have a problem concerning the association option in general.
How am I supposed to associate a Relay(controlling Siren) with a Door Sensor ?
So I can be able to turn on the alarm when the door sensor is breached even if the Home Center is not activated.
What parameters do I need to change in the Door Sensor? Which association group to choose ?
    31 views !! Nobody has got an answer ?
    Hi
    I tried to do the same some years ago and came to the conclusion that if you associate a siren directly with a sensor it will go off always, even if sensor is not armed. So I bought a UPS for Fibaro - but pay attention if you do the same, because the cheapest UPS's do not reactivate after the battery drains, they need a manual push of the external button.
    Hope it helps
    R
    Thank you rcanetta but isn't there another way a simpler way to do so ?
    Any HELP ?
    I really don't think so - UPS is the only way I believe... Just find one that reactivates automatically after battery drains.
