Hi All
I am using the Fibaro lite device with the fibaro double relays 1,5wx2
When using a scene to switch a light on, the device switches on a whole lot of other lights which I dont want.
I suspect that this is cause by associations. How do I make this stop
Regards
Ian
Open your user interface of HCL, preferably via computer rather than mobile device
Find your Relay switch and see if it is associated with annything but HCL.
You can find your way to association settings by cliicking a wrench icon on whichever relay switch is part of the scene within HCL interface (prefer computer to mobile device), go to advanced, and scroll down untill you se section "associations" it is not far below notification settings and it is above various configuration parameters
If the answer is no than you must have connected it in such manner that turns on rest of those relays (consult your electrician and or manual)
