On / Off Switch
Device type: FGS222 Switch 2x1,5kW EU
Producer: Fibargroup
Version: 2.2
Configuration: Device configured
I have connected the FGS-222 in the right way. Set parameter 14 to momentory. Do I need a blue wire (I only have L and N wires)? It doesn't say so in the manual but just to be sure.
Problem:
When turning on the light it instantly (after half a second) turns off again. The state on the HC stays on but the light is off. Changing the state from on to off doesn't do a thing but the same issues appears when turning on the light, it instantly turns off again. The light is a normal (non LED) light bulb of 40w.
I disconnected the "clicker" (how do you call the thing you press to turn on and off the light) but have the same issue.
you made my day ...
    you made my day ...
    I am happy for you but don't understand
    On / Off Switch
    Version: 2.2
    Problem:
    Please, check our platform with instructions about installation of FIBARO modules. Follow the instructions and check whether you installed the module properly.
