Imperihome scenes not found after Fibaro update
Hi all
I have updated my HC2 to 4.090 and after refreshing devices in Imperihome all scenes stopped working.
Icons on buttons have been replaced with a text message saying that scene has not been found. Furthermore none of my scenes are available in the menu when I want to add a new widget.
I am aware that cache had to be emptied from the browser on my laptop as all scenes were greyed out. Have any of you got a similar issue?
11 answers to this question
Guest chaicka
Hi all
Check the change log of 4.090 as there are changes/new features in scene's visibility settings and run type.
    Thanks for the info - I'll investigate
    I've checked all my scenes and they all have:
    Run scene: Automatic
    Scene hidden: Unticked
    Any ideas??
    Edit:
    I have installed a fresh copy of Imperihome on my iPad and can't access any scenes either (they do not display in devices list)
    Have also submitted a ticket to Imperihome but they have a tendency of not replying to my tickets so maybe someone else will have more luck
    Any ideas??
    Edit:
    ive set mine the same and have had no change in imperihome.
    ive also emailed imperihome support.
    i had my scenes run as part of tasker and using my android wear watch so need to get the scenes working again..
    Guest chaicka
    I will check again when I get back tonight, just to be certain those scenes I have are indeed still there and working. Mine do not have many scenes, just a few to set mode as away or home or off all lights.
    All icons dissapear as soon as you refresh devices in Imperihome...
    I have got a reply from Fibaro's tech support basically saying that they have changed the way scenes are displayed and of course contact Imperihome requesting they fix it at their end. Have also suggested a restore to a previous firmware.
    I have had no response so far from Imperihome.
    fair enough
    ive just had a play about with the api and found that if i create a http request as one of the widgets then it works..
    http://<ip:port>/api/sceneControl?id=<SCENEID>&action=start
    also you need to input the user name and password in the respective fields.
    this works, but is not ideal as you would need to open ports and send username and password through non-encryped http requests, bit internal network use this should be fine.
    only thing is manually entering all the scenes....... so this is a temp fix
    Guest chaicka
    The 'Scene' and 'Device' portions are broken. If no reload perform, it appears to be intact. But once reload, the 'Scene' widgets indicate as 'Device not found'. And if re-composite 'Device', though able to select the devices, nothing shows up in that device widget box once saved.
    Has anyone heard from Imperihome support??
    imperihome has now been updated and scenes now work
