UKCamaroSS 2
I've need to send hex code from Fibaro HC2 to Global Cache itach rs232 / 485.
The hex code is: 7F F2 FA 01 00 00 AE 49 FA FE FD 06 58
Using Global Cache's iTest, I can control my equipment as needed using the above hex code. However, entering the above into Fibaro, by way of a virtual device does not enable control. I have tried to add the "0x0D0x0A" string to the end, and that also does not enable control.
Can anyone suggest what is needed to get this to work?
Thanks,
12 answers to this question
