Combine AC and heating
john.van.beurden
I have a combined heating cooling system. I would like to use the heating and AC panels in HC2.
The problem is that the same valves are used for both heating as cooling.
When the outside temperature is below 22 degrees the system is in heating mode. So when a room temperature is below setpoint the valve is opened and hot water heats the room. When it is above the 22 degrees the system switches mode and cold water will flow through the valve to cool the room.
My question is how will the two panels influence each other? Is it possible to completely disable all functionality of the AC panel when the heating is active and vice versa?
greetings John.
The way the panels are implemented now i do not think it is possible. They will conflict as soon they reach the set point temp.  They would need to have the change over function i think it is called and they don't.
