I have an electric strike for an outdoor gate that I open via the FGS-211 relay with a momentary switch connected to S1. I have setup the relay as a momentary switch via parameter 14 and parameter 3 to auto off along with parameter 4 0.2 seconds.
All works fine when I use the physical switch to open the gate, it sends a electric signal for a split second. Now using the fibaro app to open the gate works fine except that the graphical status of the switch remains "ON" and does not go back to "OFF" after that split second electrical signal. I can use a scene to send the switch back to "OFF" position. Is there a way to achieve that without a scene?
help is appreciated.
Dan
  • 3 weeks later...
Try changing to 0.2 sec to something longer like 1 sec.  Sometimes the interface does not register status changes that fast. It is no problem if the electric signal is sent for a longer time.
