WUWeather scene - version = "{3.0.5}"
Fetch data from wunderground.com, send morning and afternoon forecast to your smartphone using Fibaro app, Telegram or Pushover.
Data from wunderground.com can be from a PersonalWeatherStation(PWS) or nearest LocationID(LOCID)
Example of forecast and pushoptions to use. 1'st value is smartphoneID, 2'nd value is morning forecast, 3'rd is afternoon forecast, 4'th is pushoption
Sending as Pushover message requires an own scene that monitors Pushover variable, read about it here:
All important keys like API keys, tokens etc will be saved to variable panel.
Supports many languages (EN, FR, SW, PL, NL, DE, NO, RO, CZ, GR, PT, RU (default is en))
Complete lua code (save in a new scene)
Yep don't know why. Cound 188 over 188 ()
Only changed to id psw... Etc
Hmm i don't have that error and the last ")" is there
On line 606 it reads:
fibaro:call(WU.selfId , "setProperty", "ui.lblFcst.value", WU.translation[WU.language]["Forecast"].." "..fcstday2.." - "fcst2_mobile);
it should read:
fibaro:call(WU.selfId , "setProperty", "ui.lblFcst.value", WU.translation[WU.language]["Forecast"].." "..fcstday2.." - "..fcst2_mobile);
    it should read:
    You are absolute right my friend, corrected first post now.
    That did the trick. nice
    however, it woud be nice if the VD on the phone give the complete forecast of today
    now it cuts of
    Lomg forecast is not possible, text will go over next label.
    First post updated!
    Hello Jompa,
    With the last 2 versions I don't get a telegram message anymore. (Did not have to time before to test earlier)
    I put version 240 back in and the telegram is send again.
    with 305 no more.
    Also deleted the globals of telegram.
    run scene again just to be sure but no luck.
    Don't know where to look in the code maybe you can help me out
    I will check and point out what you have miss or setup wrong. I run 3.0.5 myself with Telegram activated.
    hi Jompa,
    Tonight got the telegram message again.  Maybe I tested it to fast (update setting on 30 min.)
    Think the delete globals and run the scene new is the solution.
    Tomorrow I do a last check.
    I am trying to get this working, but I get an error:
    It concerns the line 520: local http = net.HTTPClient()
    Never mind, got it working. LUA code copied to scene instead of main loop of VD. Sorry
    On 7/18/2016 at 3:18 PM, jompa68 said:
    http://127.0.0.1:11111/api/
    Btw this eq with api.get api.post api.put
    I get this error every few hours and the script stops. What is going wrong here?
    It seems that WU has stopped their API. Can anybody confirm this also?
    I get an error: "this key is not valid due to exceeding rate plan"
    I regenerated a new key, but still not working.
     hi all,
    I confused what is the lua code with the newest version.
    and     WU.APIkey = "14eaffxxxxxxxxxxxxxx"  --Put your WU api key here       (what does WU api  mean ?)
    thanks
    Edited by malitan
    WU API = Wunderground Application programming interface
    You need to register to get an API key, but I am afraid WU does not provide any API's anymore
    Edited by Rikbast
    What should we do ? is there another provider ?
    I will do an update of this to support other providers.
    That would be awesome! thx, appreciate the help.
    Started to create a scene that supports OpenWeatherMap
    When completed scene will fill a VD with all fetched data from OpenWeatherMap API
    Still want to have possibility to send forecast as push or telegram?
    Edited by jompa68
