Hi.
I try to use linked Devices for controlling heating. I use Fibaro motion sensor as temp sensor and Fibaro Relay as relay. I can use the heating panel to set the temperature but it is possible to se this linked Devices as a thermostat I can adjust from the app?
I am also wondering if it is possible to acitvate/deactivate scenes from the app?
    Anyone?
    You need to make Heating zone in Heating panel, then you can adjust temperature in manual mode.
    Also you need this Heating zone link with room, where you have your linked device.
    In e-learning platform is very good explanation of heating panel.
    Thanks for Your reply. I undertand this but I can not adjust temperature from app? Right?
