Camera - Vivotek
pt13
Anyone have any vivotek cameras?  For some reason mine flicker when they show up on my android tablet and phones?
5 answers to this question
Have vivotek cameras (8174v and 8180). Working fine in my setup. But don't have any android devices to test with - only iOS.
  • @Kfruechtl do you know how to specify which stream you want in fibaro?  There are 3 streams from the vivotek cameras but i can't figure out how i can specify which one i want?
    Hi, I'm using the following settings:
    JPG stream path: cgi-bin/viewer/video.jpg
    MJPG stream path: video2.mjpg (for the second stream - need to set up the second stream on the Vivotek to be compatible with the HC2)
    Select display option: Display as MJPG
    Hope this helps.
    Karsten
  • thanks for that....so you don't  need to put in the "cgi-bin/viewer/" for the MJPG stream path?
    and when you say need to setup the stream to be compatible with the HC2, you just mean that it should be an MJPG stream?
