FIBARO - Out of business ASAP
Guest cberbecaru
This is unbelievabale !!!!
60W of LED lightning just welded my 2x1.5kW relay. Fibaro, 1 kW = 1000 W !!!!
Yes, I know about rush-in current, but a factor of 25x is more than enough.
How much is enough to drive 60W of LED lightning? 10kW? 25kW? This is plain stupid.
After spending in excess of 2.000 Euro, I have to find out that the software is FULL of bugs (stupid bugs), Almost NOTHING works as expected or as documented, but there are tons of false commercials. These are OK.
This company should change the business: go for advertising, you are be the best on this field.
Let some engineers take over or some lawyers should do their jobs.
i have experience of using 2x 1.5kW on 200W Led light, several various bulbs.
i can see 2 posibilities here:
you gotten faulty relay
you did not follow schematics
can you please reply with:
schematics you connected it by and model name of your relay switch (there were few generations)?
