Autostart works for only two scenes
For some reason I have two scenes that autostart; both were initially written as block scenes, then converted to LUA. New LUA scenes won't autostart, whatever I try. I have created a minimal scene from a converted block scene, that just fetches the trigger and prints it via debug, to no avail...
For all scenes, the number of instances is set to 2; I hope that this does not mean the TOTAL number of scenes but the number of instances of a particular scene....
4 answers to this question
    Solved it... For some reason the %% autostart must be added in the comments on top. Why isn't it added automatically when I select "automatic"?
    A proper explanation of what these %%-comments entail is nowhere to be found, by the way.
    only an block scene (and converted block scene) is creating the %%autostart entry, when creating immediately LUA scene one have to add that line of code manually.
    etc.
    I've created 10 block scene that I've never converted, and It looks like I've got the same issue.
    5 radiator -> 1 scene to stop radiator/ per radiator
                     -> 1 scene to start radiator/ per radiator
    Only 2 device look to have their temperature changed. I've even got issue stop/start manually..
    I've got the parallel number to 2 too... I do not understand yet why I've got this issue.
    I do not know If I'm doing something wrong...
    Here is the block scene -> displayed in LUA
    For a weird reason, I look like the convert to LUA did not work on some of my scene.
    It remove the part
        fibaro:call(8, "setTargetLevel", "23");
        fibaro:call(8, "setTime", tonumber(os.time(t)) + 120*60);
    which would be a reason why my scene were not working. I'll keep you post.
    There is definitively an issue with the converter from BLOCK to LUA. Some part from the execution are removed during the convertion.
