Send data via HTTP POST request
I've got a code that is sending the data via GET request:
-- performs a GET method on given uri, takes function as a parameter in case of success
getMethod = function(uri, success)
  local http = net.HTTPClient() -- creating object for performing HTTP call
    http:request(uri, {
        options = {
          method = 'GET'
        success = success, -- function executed in a case of successful connection
        error = function(err) -- function executed in a case of connection error
          print('error' .. err)
The "uri" is a normal link which looks like =
And that works, but i need to send data via POST request. When i change the method to 'POST', it connect to server, but it doesn't send data. I don't exactly know how to write this data.
Would be really grateful for any help.
5 answers to this question
You have to send the data in the options part like:
    Still can't send data....how do you describe variable payload? Something like this? payload = "action=create&description=myData&moreDescription=moreData
    What do you need to post?
    In the example above the payload would be something like: data1=vari1&data2=vari2
    I have the following code and it works perfectly in a scene:
    I want to insert a globalVariable value in the "data" set.  For example, I want to send my current switch energy consumption.
    Any suggestions?
    Is this what you intend to do?
